Nostromo N52 Speedpad Question
polydiol
I'm unable to get my Nostromo N52 speedpad to work with Battlefield Vietnam, is anybody else having this problem? Anybody have any solutions?
I found out it works great when I unplug my Logitech joystick but when I plug the Logitech back in, it doesn't work.
I wonder why that is? Is it a problem with game coding (my thought), or a hardware problem? Maybe a setting in-game needs to be enabled?
I had a problem with GTA Vice City if my Nostromo was plugged in. The character view would just spin around.
No problems so far with BFVietnam and my n52. The only feature that doesn't work for me is setting a "default" profile. When I do that sometimes the default gets activated even when I've got a separate dedicated profile for a game. Other then that it's a great product, especially for the macros.
Are you using any other controllers to play the game such as a joystick?
No other controllers except 2 Logitech mice (mx700 usb, mx500 ps2) and a Logitech Internet Navigator keyboard (ps2).
Have you checked for updated drivers for you Logitech device?
I lost my n50 due to it breaking, I miss my speedpad.
My N52 is working fine with BFV and I am using an old, old joystick I had laying around. I dont know what I would do with out my N52!
hmm...I have my N52 and Logitech Wingman RumblePad plugged in at the same time with no issues. Not playing BF though. I would look to BF being the problem here. Although Logitech's software leaves a little to be desired.
You sir, are an idiot.
edit: I think the post got edited, so disregard what is said above.
