northbridge southbridge heatsinks
robman_rob
Does anyone recommend replacing the heatsinks on a motherboard in an attempt to lower the motherboard's temperature instead of finding a way to increase overall air movement through the case? Does it actually do anything much to replace the heatsinks on motherboards?
I got a Tt Extreme Spirit II for my BA2. The bare stock sink got too warm. Seems to have helped a little initially, but lately, I think I've screwed up the power to it.
No, I recommend replacing/reworking the heatsinks AND increasing overall air movement.
The question is too broad, it depends on the board and what is used, heatsinks vs heatpipes, what chipset etc. In general recent Intel chipsets run very hot and the MCH/Northbridge is overclocked just like the CPU when raising the FSB to overclock and thus paying attention to MCH/Northbridge thermals allows higher OC as well as improving stability and reliability.
If you intend to OC it is standard procedure for a high perfromace build to rework/replace the board thermals. Sometimes all is needed is to replace the factory paste and use better mounting hardware. The large tower coolers popular now eliminate the downwards "blow by" of the stock intel heatsink and one is wise to provide proper cooling for the cpu voltage regulation circuity around the cpu socket and replace that lost air flow.
Sorry I meant to ask which one would make a bigger difference.
With the rules of heatsinks, increasing heatsink area has an exponential effect on cooling to the order of 2 or 3, whereas increasing airflow is more linear, iirc.
In the past with motherboards I have used, the answer has always been different. Some of my motherboard's had fairly large heatsinks already, therefore increasing heatsink size was inconvenient so I opted to increase airflow. The downside to adding airflow, is more noise. Some of my motherboards however had no heatsinks on Southbridge or power regulators, and an undersized heatsink on the Northbridge, so I opted to replace the heatsinks and add larger ones.
