TheCommander
- Apr 2, 2003
The gigabyte mobo I have has a heatsink on the northbridge that kind of wobbles around when you touch it but it reverts back into place after letting go. Is the heatsink on the northbridge supposed to be tight? This is the second gigabyte board I have that has the heatsink wobbly.
The board is a MA770T-UDP3
http://www.newegg.com/Product/Produ...chReport&cm_mmc=OTC-TechReport-_-NA-_-NA-_-NA
Also, is it normal for gigabyte boards to have insanely high northbridge temps. I remember the last board I had, the temps reached over 100 degrees.
