Northbridge cooling
rgratto2
Here is my dilemma: The fan on my northbridge has gotten increasingly loud recently, so much so that it is the loudest component in my system and is rather annoying. To remedy this, I purchased this little fan. When attempting to put it on, I found out that it won't fit on the current fins in place, as the fan groove is rounded for the specific crappy fan that came with the board.
To add to the problem, my board is very poorly designed, as the northbridge is far too close to the PCIE slot, and my fat 8800 gts hangs about halfway over it.
Is it imperative that I have a fan to help cool the NB? what if i just left the fins and called it a day? Or should i perhaps get this fan and some Arctic Silver Adhesive and just replace the entire damned thing? Frakking shipping is so expensive these days, that would be like half the cost of that little order!
Try standing the fan up on end, blowing air across the fins? Thats better than no fan at all, right?
Intriguing - how are those staying in place?on in your pic Nanan. Oh, and nice ram btw, I have the same sticks!
If you have a big heatsink on the northbridge, then yes you can ditch the fan. But since you have a low-profile heatsink on that motherboard, not a good idea to leave that NB fanless.
You can always just superglue, tape, hotglue, tie, or screw in the fan to get the fan to stay on the NB. Looks very doable to me with that fan you already bought.
Perhaps I should try to get longer screws, and just have the fan sit on top of the heatsink a little...
Nothing like a little computer freeze to motivate me. After my freeze during TF2, I touched the fins and they were piping hot. I then decided to try and screw in the fan so that it was standing perpendicular to the fins, as suggested above.
I happened to find 2 longer, slightly girthier screws. I went and was loosening up the holes of the fan, and managed to get the first one through. I had found the right screwdriver head, so the second one was flying through when, all of a sudden, the frame for the fan snapped and the fan itself just completely detached. I was a bit pissed, but then I luckily stumbled upon some Scotch adhesive squares. Needless to say, the fan is now attached with one of those little double sided adhesive guys, and my case is now pretty damned silent. :)
Just played a bit more, was getting some bizarro lag (potential issue?), but no freeze. Only time will tell...
Hmm . . . I'd check some of the thermalright NB solutions. I have a HR-05 SLI/IFX cooler which fits snugly between my Enzotech HSF and 8800GT . . . no fan, but has enough surface area to dissipate.
With Epox 4PDA2+ motherboard's stock, fanless heatsink, I notice a lot of lag (as if CPU is throttling because of the heat) or slow downs in both Windows XP 32 bit and Vista 32 bit when it gets too hot. Part of the problem is that I use a Thermalright SI-120 and it's raised about 3-4 inches away from the board. Any air that gets drafted to the northbridge heatsink is not enough to dissipate its heat under heavy loads or high temperatures in the summer. I took everything out the other day and dusted my case bit by bit (All grils, fans, crevices), rewired all cables and I still felt the lag.
I thought about the northbridge heatsink which never had much air directed at it. With the stock P4 fans, they're usually designed to push air directly onto a big block, heatsink. When the air hits the heatsink, it spreads out in all directions, essentially cooling the northbridge heatsink adjacent to the CPU heatsink. So I temporarily mounted a 120mm 90CFM fan to blow across the northbridge heatsink. My Windows XP has gotten much zipper, even when I played WarCraft III for 3 hours straight, loaded a bunch of websites through tabs, watched a movie, and converted a movie file. So I'm pretty sure the chipset needs to be cooled better.
I too have been looking for a new northbridge cooler. The dinky heatsink over my P35 is way too hot for my tastes. It seems the ones that're actually worth buying are between $20 and $35. If you're looking for something passive, Thermalright HR-05s are very popular, but the Xigmatek Porter N881 and Noctua's NC-U6 share the same basic design. If you want a quiet active cooler, the Swiftech MCX159-Cu and Microcool Northpole Whisper Xe are both good coolers.
For a very cheap DIY setup, I've seen some people ghetto-rig a 40mm fan to a Zalman ZMNB47J heatsink. Tota cost would half of these other coolers, but I'm not sure if it's enough to cool some of the hotter chipsets out there today.
