Northbridge Cooling
I recently just recieved my K9N SLI Platinum mb back from MSI as a result of the northbridge apparently overheating. Now I"m looking for a new heatsink, preferrably paired with a fan. I don't think the fan is possible though because I'm using a 7900GTX and the northbridge is positioned so that my card hangs out overtop of it. What heatsink would be the best to get that would go with this board, and are there any that include the fan that will fit along with the graphics card?
im not all that familiar with that motherboard but can safely say that the HR05SLi is without a doubt the best PCI-e-avoiding coolers out there.
ran my dfi sli-dr (285x9, 1:1, 1.8v through nb) at 30C load. that was without a fan.
you really need to get this, provided it fits properly.
Do you have a pic of how you mounted it? I was just wondering how hard it is to stay away from the CPU cooler. I guess it isn't as big a deal with the Nforce boards compared to the newer Intel ones.
Alright thanks. Either one of those should actually do nicely. They both look like they would angle out of the way of the graphics card. Now I"m also kind of curious, cause I would like to be able to monitor what the northbridge is running at. I have a program from MSI called Dual Core Cell which seems like it's supposed to be able to monitor the temperature of the NB and PS..but all it says is that it's not available. Is there something I need to download or buy that would allow me to be able to monitor the temperatures?
Yeah, never noticed that before... talk about "He Haw". Maybe they could use some duct tape and goat feed as well....
