North and Southbridge manufacturing process!
Nielo TM
Does anyone know what type of fabrication processes used to manufacture north and Southbridge (e.g. 90nm or 120nm)?
The reason I ask is because as bandwidth increases, the controllers get warmer (obviously) but, they are now beginning to become more problematic then before. So why not manufacture them at smaller scale (say, <65nm)?
Intel.com should tell you anything you want (and more than you need) to know about the chipset chips. Decisions like that are typically economic ones concerning Fab capacity. yeild, costs. selling price, demand yada yada, unless there is some overwhelming engineering need to shrink the process. MCH's get prettty hot when OCed but stock their power rating is less than 20Watts.
AFAIK, Intel chipsets (northbridge, at least) usually are "one step behind" in terms of manufacturing technology, relating to CPUs, as to keep manufacturing plants busy and profitable. That way, while one fab switches to a newer process, the other ones (or at least one of the others) keeps with the same manufacturing tech, for older CPUs and chipsets.
So, right now there is a statte-of-the-art 45nm fab (at least one), for Penryn-based CPUs, while most of them still are 65nm. And there's the chipset plant, which ATM are all 90nm, as far as I know.
As for Southbridges, I don't really know the manufacturing tech they are built on. But since they usually don't get as hot as Northbridges, it wouldn't surprise me if they were kept on 90nm or 130nm manufacturing tech, or even bigger, since they are huge, compared to Northbridges. I don't really know how they jugle all of them, though.
Cheers.
Miguel
Thanks for the great infos
As far as know, nearly all modern (high-end/mid range) northbridges have some sort of heating issue. To add to the problem, manufactures are implementing inadequate heat-dissipation system. Sure, ultra-high end boards are equipped with standard/advanced heat-pipe system but not all of are going o take advantage of dual/quad GPU ports.
PS: South bridges are now beginning to becomes an issue as well.
All chipsets except for the ATI chipsets get really warm.
Actually, Dan...
The G33/Q33/P35/Q35 chipsets range between 5.5W idle and 16W load TDP. That's a fact. That's also lower than prior chipsets, which typically had lower idle, but peaked around 20-25W TDP.
http://www.intel.com/design/chipsets/datashts/316966.htm
The AMD690 chipset peaks at a mere 13.97W TDP using the two-resistor model. I have not seen or reviewed the Delphi models.
http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/41977_rs690_ds_nda_3.03.pdf
nVidia does not publish or share thermal specifications, except with parters. In no small part because the fact is, nVidia's chipsets do run hotter than everyone else, and always have. By a wide margin. The TDP of the nForce3500 without question exceeds 20W, and is estimated to be about 27-35W - or nearly double the AMD690. The idle TDP is estimated to be around 10W by itself.
I did some "informal" experiments swapping around chipset heatsink assemblies with two boards - one nVidia, one Intel - that had the same chipset temperature normally. Placing the Intel heatsink on the nVidia resulted in chronic overheating. Placing the nVidia heatsink on the Intel resulted in a 3-7C drop in temperatures.
So there you have it.
Actually, Dan...
I realize this, but I wasn't getting into specifics. The newer Intel chipsets are much cooler running than the older ones, but still all the chipsets I've worked with in the last couple of years. I haven't worked with the newest AMD branded chipsets, but the last ATI branded chipsets ran quite cool and used very little power.
This is true, and even on the high end boards the first thing anyone that intends to go for a high OC should do (after running the board at least overnight) is to replace the shoddy thermal compound and mounting of the stock heatsink/heatpipe and also ensure the power MOSFets are cooled well, if not to remove and replace the entire assembly with high performance components. This has been SOP for a long long time. It is a real shame the manuf have not caught on, $25 of copper heatpipes etc and 2 cents of crappy paste poorly applied.
