Normal Temps or What
JKownz
I have a swiftech water cooling kit. I have 2x2500Rpm fans on the 80mm rad and its connecting to a a64 3400 Northwood and a 6800 gt I am ocing my gt now to ultra speeds and i oced my cpu to 10.5x240= 2,520. i am getting 39-43C Idle and around 45-55C Load is this ok or is this not normal? Or should i get a second rad? Mobo is a dfi nforce 3 so you know and cpu voltage is 1.61 idle and goes up to 1.69 on load.
Those temps are ridiculously low for a single 80mm rad cooling those components.
JKownz said:
Ok thanks, just wanted to know :p
why he says ridiculously low...i am assuming he is suggesting that ur temp sensor might be screwed up? as temp should be much higher with 1 80mm rad
could be, but as long as your machine isn't getting unexplained lockups or blue screening during heavy load then the temps can't be too bad. I say well done the 80mm rad
