I've got a RPC-4224 that has 2 bad backplanes that I need to replace. I've done some research and found 2 diferent ones on IPDirect. Which is the right one and if either will work, what's the diference between the two? Which is better? Here's a link to the ones I'm looking at - http://www.ipcdirect.net/servlet/Categories
Mine currently has the green ones. I would like to get the ones with brighter LEDS but heard there are problems with them. Advice is needed.
Thanks
Richard
Thanks
Richard
