I have a chenbro 16 drive chassis. Looking at the norco 4220 chassis on newegg, the cases look nearly identical.
The hard drive trays on the chenbro are a tight fit, and the drives are packed together very tight. There appears to be no room for airflow. If these were 1u or 2u servers, i wouldn't be too concerned. But when the drives are packed 4 or 5 high, with no airflow, i start to wonder about heat dissipation.
When i'm loading drives in these chassis, it feels like a bad design. When drives are packed into these chassis 3+ drives high, it seems like the heat from the center drives has nowhere to go (no airflow).
While computer components have come a long way regarding reliability over the last ten years, it just feels wrong. In my experience, the two biggest enemies of computer components are heat and unregulated power.
Am I being paranoid?
Have hard drives advanced so far, that heat is not an issue for reliability?
