Noob question...
Hulk
I plan on getting a COOLER MASTER CM Stacker case, it has room for 4 120mm fans up front. It comes stock with one and I plan on buying another 120mm fan.
Question is, what kind do I get?
"Sleeve" or "ball" type? Do the sleeve fans only go in the side windows?
Also while I'm on the topic, COOLER MASTER CM Stacker's side has a 300mm round grill/hole on it, can I mount a 80mm or 120mm fan on it?
