Sorry for asking such a noob question, but in a push-pull config, do both fans face AWAY from the heatsink?
Also, would there be a detrimental effect if the two fans are not of the same speed/cfm? I want to use an NT-06 Lite I have lying around, and strapping a fan on it blowing downwards (putting the fan under the heatsink), and the PSU pulling air upwards (I have an SG-02 case, so the NT-06 would be sitting directly under the PSU fan)
Summarizing, the airflow on the heatsink is going to be the PSU fan pulling air upwards, and another fan pulling air downwards. Unless I have the whole idea of the push-pull fan config wrong, I think that this will work quite well.
I'm currently using a Scythe Shuriken with the fan on top pulling air upwards toward the PSU, and I'm seeing idle temps at around the mid to high 40s and load temps of mid 70s to low 80s with my current OC. I just want to improve heat dissipation as I'm scared that I'm heating up the CPU too much.
Looking forward to getting helpful advice.
