- Nov 14, 2004
So, I'm curious what controls the maximum memory capacity that a motherboard can support. I thought that with the memory controller on the die of the cpu, there would be no difference between various motherboards as long as they had the same socket.
Guess not. For example, I have a Gigabyte H67N-USB3-B3 which is running with 16GB of memory (2x8GB dimms). I want to upgrade to a Z68 motherboard (specifically, the Giada MI-Z68) but it only claims support for 8GB memory.
Is this just outdated documents, or is it something controlled by the BIOS/UEFI? Can I hex edit a value to recognize more memory?
Never really thought about these things, and doesn't seem to be too much specific info around (or my google-fu is lacking), what do you think [H]?
