Noob overclocker needs help selecting intel motherboard
bushdiverq
Hi all. I have read your board for a while now and i enjoy the information i get from it.
I was wondering What motherboard i should aim to get when i build my new system. I am a gamer so i want some eye candy. I already have a dell 2005fpw monitor. So i am going to need the entire setup. I think i want to go with a intel core 2 duo or maybe even an extreme processor. I want to spend around 1200 bucks for my setup. I want to start overclocking so i want an overclocker motherboard.
Any help with motherboard selection would be great.
so you know, that C2D xtreme processor will eat up like 90% of your funds, heh
Get a e6300/e6400, a gigabyte DS3 (with or without onboard video, choice is yours),
Some ddr667/800 ram, again, your preference
then get some heavy duty video cards.
Throw a decent HSF on the chip and start bumpin it up.
Get an E6400. Overclock it to like 2.8ghz + (you could probably get to 3.4ghz if you get a good HSF) if you have good case cooling.
Get an Asus P5B Deluxe (or P5B-E if you need to save some cash). DS3's are good boards too, but have been known to die randomly after a few weeks/days/months.
Get 2gb of some good DDR2-800 RAM (OCZ, Crucial or Gskill. Gskill being the brand of choice)
Get a 7900GTX / GTO (if you can find a GTO) or wait for the new 8800's to come out, and see a massive price drop (possibly) on the 7xxx series!
CPU: 220
Motherboard: 184
RAM : 249
GPU: 500
Thanks for the info. Do you think the core 2 extreme will drop in price when the quad core processors come out?
Nope, not particularly... Maybe a few 100$. But it'll still be really expensive.
And for what? It's proven that almost EVERY E6300 can hit X6800 speeds with ease!
Ya i dont consider my case and psu into my price when upgrading. I have a lian li tool less case now. PSU, i consider disposible income lol so they dont count in my rough estimate of price(never know when that brownout is gonna take it out with your UPS). I currently have a ENERMAX Liberty ELT500AWT. I think it should carry over ok(i got in in hopes of getting an sli pc but i i really have no need for it).
I got another question now after looking at the asus boards.
On new egg it says 4 onboard USBs Does that mean the rear usb ports or are there 4 additional ones for say the front panel of my case.(my msi kn8l only had 2)
strike the question about the WIFI if i upgrade to 802.11n it would be a waste.
i like the 6400 for overclocking--it's nice to have a little extra multi just in case your sitting on the edge of where you want to be and ars just short a few fsb-mhz .there is no reason to spend more for a extreame edition and overclocking the 6300 or 6400 will get you the same power for just a little $$$.
i like the gigabyte ds-3 and the s-3 965p's , the biostar t-force 965PT and the asus p5b-series for top end overclocking . even the foxconn 965p can overclock quite a bit . the thing is try to find some good ddr 2 that can really hold up to high speeds .
my gigabyte s-3 nearly the cheapest of the lot--is doing 480fsb with a 6300 and has been bone stable there as well --if my ram was a bit better i could hit 500.
with a 965p i don't even consider a overclock sucessful unless it hits 450+ fsb--LOL :cool:
I'd get a 6400 and a DS3 for a "budget" combo. The only thing I don't like about the Gigabyte board is the fact that the passive northbridge heatsink gets very hot. I'm thinking of replacing mine.
p5w dh is super easy to overclock, a safe option as well just a little $$ for your budget. I've skimped on mbs before (p5n sli) and regreted it horribly.
This is what I am looking at. I just did a quick price check at newegg. What do you guys think of this setup?
I already have a decent power supply
COOLER MASTER Centurion 532 RC-532-SKN1 Black Aluminum bezel, SECC chassis ATX Mid Tower Computer Case - Retail Model #: RC-532-SKN1 Item #: 82E16811119094 $20.00 Mail-in Rebate $74.99 -$5.00 Instant $69.99 (I love the placement of the front ports)
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400C4 - Retail
Model #: TWIN2X2048-6400C4 Item #: N82E16820145034 $40.00 Mail-in Rebate combo with motherboard $524.99
ASUS P5W DH DELUXE/WIFI-AP Socket T (LGA 775) Intel 975X ATX Intel Motherboard - Retail Model #: P5WDH DELUXE/WIFI-AP Item #: N82E16813131025
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail Model #: BX80557E6600 Item #: N82E16819115003 $332.98 combo with cpu cooler
Rosewill RCX-Z2 80mm Blue LED Reverse CPU Fan with Three Heatpipe Copper Base Heatsink - Retail - Retail Model #: RCX-Z2 Item #: N82E16835200012
eVGA 512-P2-N637-AR GeForce 7950GT 512MB GDDR3 PCI Express x16 KO Superclocked Video Card - Retail
Model #: 512-P2-N637-AR Item #: N82E16814130066 $10.00 Mail-in Rebate $289.99
Subtotal: $1,217.95
I was going to go with the e6400 and the p5b - deluxe but decided to go with the e6600 and the reviews on this site recommended I get the p5w dh with this processor. It would be a little cheaper to get the e6400 and the p5b-deluxe so is there a noticeable different between the two? I have read some bad reviews of the 965 chipset and cas 4 ram, something about it not supporting it, does anyone have any information on this?
i might be missing something if soi will add it later.
I forgot a vpu so i added it in
Don't get an extreme processor, only get one if you want WR's and have LN2 cooling at hand which 99.9% of us don't have or want to have.
As others have said, the extreme processors are ripoffs, ignoring the power cost you could buy a phasechange system with the difference. The power cost makes it ugly though for a 24/7box. 750w*24/7 = 6.600kwh or $500-2000/year in energy costs. :eek:
