Spazilton said:Symetrical MultiProcessing. You can turn it off very easily. Just remove one of your processors. SMP is the whole point of a dual core or dual cpu rig.
venm11 said:Hmm... does this mean that you *can* run different opterons in SMP configurations? mix-n-match.
FreiDOg said:Depends on the board, and exactly what the diferences are.
Different steppings aren't normally a problem.
Mixing revisions is a bit dicey. You can have mix C0 and CG on a lot of boards, but not B3 and CG or CG and E*. You really need to consult the motherboard's documentation to see what is and isn't compatible.
FreiDOg said:C0 and CG revisions are fairly close, some boards support mixnig them some don't.
Update to the latest BIOS from Asus, put the C0 core in CPU0 and hope.
If that doesn't work, buy another CG revision 242.
