Since I haven't built a PC since well A LONG time ago.. everything has changed.
I do almost ALL photoshop work, internet, the basics other than photoshop and multitasking. I DO NOT GAME AT ALL.. Not even tetris.
I am going to use either a 24", 30" or the Westy 37" displays. I think I need a pretty good video card for the 30"'s and don't want to spend all that much just to run the display. I would be OK with the 24" display if I have to.
I was thinking of going with these:
Intel Core 2 Duo E6400 Conroe 2.13GHz
$188 http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=E6400&x=15&y=27
OR
$227 Intel Core 2 Duo E6600 Conroe 2.4GHz 4M
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115003
RAM PC2-6400
POWERCOLOR X1950 PRO 256MB 256-bit PCI Express x16
$130 AR http://www.newegg.com/Product/Product.aspx?Item=N82E16814131026
OR
Radeon X1650XT 256MB
$100 http://www.newegg.com/Product/Product.aspx?Item=N82E16814142090
Not sure on MB, PS, or HD. I DO NOT plan to OC, but i could as long as it was ROCK SOLID stable and I am not worrying about when it fails on me.
I want to stay under $800 if I can, but not sure that is possible. Is any of this overkill / underkill?
Any thoughts? Thanks guys
Ryan.. btw first post.
OR
RAM PC2-6400
OR
