Noise from motherboard?
TeknoZX
First off, I'm creating identical threads in other forum sections because I have no idea where this noise is coming from. Apologies and admins delete or lock or do as you see fit.
I hear noise from my computer. Not the normal noise. It's like a high pitched noise but not really. More like static but I'm not sure. Like maybe an electric hum? I dunno. Anyway, I hear it evey now and then. I hear it when I'm scrolling a window but it's especially noticable when I'm moving a window with the mouse. Like as I move the window, I hear a corresponding noise. Move it slowly, hear a "slow" noise. Move it faster and hear a noise that is faster and more constant. I've checked the usual suspects. Not the HD or any fans or my monitor or speakers. I read somewhere that RAM can cause this noise but I've switched banks and still noise. I've cleaned out my case, vacuum and can of air. Anyone have any idea what can be causing this noise? It's very awkward to hear this weird noise. Thanks.
First things that comes to mind: Is it a wireless mouse? Wireless nic? Anything that could be causing interference, like a cordless phone?
I've seen static on monitors with accompanying(?) noise caused by a desktop fan before.
sometimes onboard sound is known to make a sound when the mouse is moving, I can hear mine if i turn the volume all the way up, but I dont know about the motherboard making sounds by itself :confused:
P4 Northwood 2.4@3.2
Geil PC3500 512x2
SB Audigy
XFX 6800NU with NV5 Silencer
2 Maxtor HD's
Bunch of fans, none of which make this noise I'm SURE
Logitech cordless MX duo, keyboard and mouse
Samsung 192T LCD
Thing is, why would it ONLY make sound when I'm scolling and moving a window? It seems like maybe graphical? It's like a slight buzz, almost like very quiet HD activity but constant.
Thanks for the help and input.
Can you try your onboard sound instead of your Audigy and see if that clears up the problem? Just to see if there is some interference on the sound card.
The thing about switching to onboard audio, the sound isn't coming from the speakers, external or internal. It's like an electrical buzz you hear from a transformer but weaker.
So you don't hear the noise at all with speakers unattached. Hmm...I've heard when there is noise like that when the mouse moves, but usually the noise comes out of the speakers. I have heard that something else on the board makes noise, but I can't remember what it is. MD_Willington would know though, he's commented on it several times. Send him a PM and see if you get a response.
Does it do it when holing down either of the mouse buttons.......this might be why you only notice it when dragging things around?
Are you sure it's not the monitor making noise? Place the cursor over the window and get ready to drag it like you normally would, turn off the monitor, then try. I'm thinking it might be the monitor because it's possible for LCDs to make noise due to their high voltage inverter for the back light.
no sound when i'm holding the mouse buttons or anything. i doubt LCD's make noise but just in case, I did it with the monitor off...noise.
my board does the same thing. It does it when I have something with sound playing even if its muted. It also does it when i move my mouse now because I changed the hz from the default 200 to 1000. Not exactly sure what its from but I know that those 2 things cause it. However, I've had no problem with anything running weird so I wouldn't worry about it too much.
I doubt its the monitor because you would hear that all the time or at regular intervals, not just when you move your mouse or something. It does it on my comp on both my crt and lcd.
It's a noisy world inside that little box on the desktop.
If it isn't electrical interference from the buses etc, then it may be interference from cables (read = transmitters and receivers) or noise from the power section of the mainboard (usually singing toroids or power supply components), some boards just do this and it is highly annoying, even my Abit BF6 workstation did this, especially when scrolling with the mouse.
So is it a PS2 mouse, USB or wireless?
Try a different mouse?
Is the sound coming from the video card, monitor, power supply or mainboard...
Let the trouble shooting begin!
MD
PS if this is less than coherent, I'm sick so I'm blaming the meds... lol
