Noise from APC Smart UPS SUA1500?
EnderW
Anyone own a APC Smart UPS SUA1500? If so, can you hear any noise if you put your ear up to the vent on the side?
Ender, just giving you a heads up here b/c it's the only way to contact you...
YOUR PM BOX IS FULL! :)
Most UPS's make some sound. IIRC yours has a cooling fan, how it's set to turn on I'm not sure but it may be that. Also there is usually some noise from the battery charging system. My back-ups 650 makes a very noticable charging noise right after the power comes on after an outage. If it's really quiet you can hear a very quiet on/off whine as it keeps the battery topped off.
Yup, I can hear a buzzing noise when I put my ear next to the SUA1500 , but it's inaudible otherwise as it sits under my desk, except of course when it's discharging.
