No vga out
I run an msi b450 a pro max with a 3600x, 32gb ram and rx 570 for a minecraft server running ubuntu. This morning I shut it down to install a 3080. When I started back up the monitor went on and the cursor blinked and then stopped. The VGA debug light just stays on. Swapped back to the 570...same thing. Different slot, same. Reset cmos....same. one stick of ram....same. even different gpu...same.
How could a gpu swap kill a mobo?
Static discharge? You might have moved the motherboard slightly and it is shorting out in the case now. Take the motherboard out and try it on a box or something.
Well, this is annoying...
I take it to the other room and it works...
It seems to be some issue with my kvm.
