No Signal Problem
Kwak
Hello, not sure if HardfForum allows pc tech help but here goes.
The built-pc was running fine for the past one year. I was last working on a website (Wordpress with plugin) and got a "script not running, run or close" message because of a jquery conflict with something.
Shut down Firefox and then the monitor display went off. No Signal Detected. I rebooted PC but nothing showed up on the display. The PSU looks to run fine. No excessive noise from hard drive.
Hardware
Radeon 3850HD videocard
ASUS LCD - connected to PC with DVI cable, and VGA with XBox.
2 sticks of ram (held in place)
160gb hard drive Western Digital
Antec 380 Earthwatts
Win XP Pro
I opened up PC case to check if all hardwares are in place. CHECK.
Reseated the videocard. CHECK.
Used a VGA cable to test on other PC, No Signal Detected. CHECK
LCD display works as the xbox displays it.
What other steps would you check to fix this problem? Thank you greatly in advance.
Hit the stickied "Basic Troubleshooting Guide" on what to do when your system doesn't POST.
