No Power on New System
Pegesus
Hey all,
I've never encountered this problem before maybe one of you have and have some insight as to a fix.
I just built a new system and i go to power it up and i get power for nearly a second and then nothing. I've stripped the system down to its bare bones and nothing changes.
I am running the following:
AMD 4200
2 Gigs Corsiar XMS
WD 120 Sata Drive
X-fi Fatal1ty Gamer
7600 GT
Coolermaster 450w
MSI mATX MB
LG DVD-r
I really have no clue as to what the problem can be. LIke i said if i push power i get power for a second then nothing. Also after it powers on for a second i cannot get it to power up again for a second for like a min or so.
I've check my jumpers and all seems well. Please help i need to get this system up and running.
Thanks
Silverstone LaScala Case
Check the back of the power supply for a 110/220 switch. Sometimes they come on the wrong setting.
Yeah that might be it however. On my PSU i do not see that switch.
I have this model PSU
RS-450-ACLX made by Coolermaster. If anyone is familar with it and knows how to check this please let me know.
Ok update...
I swapped out PSU's and this time made sure it was set to the right setting.
I still am getting the same problem now with a slight change. Now if i hit the power button it powers up and then goes off but if i hit it again it powers up and keeps running. However there is no display at all. The is no HDD activity just running fans.
The only way i was able to get it to this point was to remove the clear CMOS jumpers completly now they are all open. Could that have anything to do with this.
Please if you can help i need to get this thing up and running and i am running out of ideas.
You don't want to leave your jumpers "open". Check your mobo manual and see what the correct settings are for your application and start over. Pull the cmos battery for a few minutes and then install the jumpers in the correct position, and re-install the battery, and see if that helps.. Good luck..
ok I've tried that and now i can get it to power up for a second again but then it just goes off. And once it goes off the front system LED light just blinks until i actually turn off the power from the back of the PSU.
Could it be a bad MB... the only problem i have with troubleshooting this is its an AM2 socket and i don't have another board to test with it.
Any other thoughts?
Ok new update after fiddling around. I can get it so it has stable power however right now i get no picture whatsoever. The monitor just stays on an amber led never goes to green.
Any ideas
I'm having the same issue with my new computer I ordered. I had the 3 seconds thing but if i fiddle enough I get power but no video. There COULD be a short in the case which I'm thinking is my problem. Try setting up your computer without the case on a wooden table or cardboard box of some sort.
I was told to try that too.
Yeah i tried that first off. Wasn't the issue i even swapped it into another case as well. And still nothing. I've tried using RGB connections and DVI connections and same problem.
What i also found strange was the fact that if i pulled out all of my ram and turned on the system i wouldn't get a system error beep.
I'm thinking its just a bad MB but if anyone else can offer some advice that would be great, i'm going insane trying to troubleshoot this
I fixed my by setting it up completely on card board. You can trip the mobo on by hitting the 2 power pings with a penny or screw driver. I did this and it worked so it's my case.
So you tried it OUTSIDE of its case, on a cardboard box, and it still wouldn't power on? You do have all the power connections plugged in, right? Did you have a speaker plugged into the board when you tried no ram? What model is the spare PSU you're trying?
The system turns on now whether its inside the case or not. I've even tried it in another case. Its the monitor now that doesn't turn on it just stays on amber rather than going on with the power of the system.
I've tried using the onboard video as well as the 7600 i have and neither work.
I've ordered another MB it'll be here by tommorrow. Hopefully that will fix it.
Like i said this is driving me crazy and i have exhausted every option that i can think of, unless i'm missing something.
Thanks for all the help. Please let me know if you have any other suggestions
Actually it could be the monitor itself thats the problem. I once had a monitor that wouldn't display images unless the monitor cable was positioned a certain way. So if possible try another monitor
I would first recommend taking the system out of the case.
Use only CPU (take it out and reseat it again),one RAM stick,and the GPU......see if the board will post............you will need to "short" out the power on switch on the MB with a small screwdriver.
Of course youll need the 24 pin,and 4 pin connected......also connect one molex to say a dvd drive just to put some load on the 5V rail................
If you POST.....then add one more RAM (make sure the RAM is in the correct slots for what you are using...............ie correct arrangement for 2 1GB sticks for double channel,POST,add the HDD,POST etc............if all is well then assemble.
Go into the BIOS and disable the onboard video,too.
What MB are you using????
i've had a bad mobo and similar symptoms occurred. i actually never fixed it completely, but i got it working and it only caused problem when booting.
i remember doing a series of things like reset the CMOS and checking the memory.
i'd also check to make sure all the capacitors (or other mobo parts) aren't bent or worse.
good luck.
I'm using MSI K9VGM-V MB.
I'm gonna try what you said Magoo. I never shorted out the power on before so maybe that will work.
And as for the monitor being bad. I have tried this with 3 other ones and nada on all.
I'll be back
