- Jul 24, 2007
Ok, so I have had a bit of a renewed desire to overclock my setup (in sig) since I have a GTX 470 on the way. Got 2GHz FSB/3.5GHz CPU/DDR2-1000 stable which was really awesome. I wanted to see if I might be able to squeeze out another 100MHz. Well, The computer failed to boot and did the normal starting to boot, turning off, rebooting that it usually does if you push and overclock too far. Except this time the computer never came back.
I hooked up a speaker to the motherboard to see if there were any error codes being thrown and nothing. I noticed that all of the fans connected to the motherboard seemed to be getting power in lumps (the LEDs are flickering a bit) with no difference being made if they are connected to the motherboard or to the power supply.
Now I did disconnect the PCIE power connectors from my 800GX to see if I could get the computer to throw a code and it did, so the motherboard seems to be at least partially working. I also removed the CMOS battery for both a short and long (1.5hr) time and it didn't change anything.
Is the problem with my power supply? Did I accidentally kill my motherboard? When I removed my video card to get to the battery did I somehow accidentally break something?
I don't really have any other power supplies I could use to test. I have one in my HTPC that has the connectors I need but not the amount of power I need (would it be fine as long as I didn't actually try doing anything?). I am just looking for more options to narrow down my issue.
