forrehmmnd
- Jan 25, 2007
Ok, I was playing counterstrike source, when my pc froze, because of a slightly unstable overclock (only freezes like once a week.). I rebooted to discover that I have no internet. I checked the wired internet, its good, checked the router, its fine. In the hardware devices menu under the network adapter list, it shows my wireless card with an error triangle by it. the error is as follows
This device cannot find enough free resources that it can use. (Code 12)
If you want to use this device, you will need to disable one of the other devices on this system.
You need to restart your computer before the changes you made to this device will take effect.
I have tried disabling other devices, but to no avail. This just started happening after i rebooted from the freeze.I dont know what they mean by resources, do they mean cpu power, memory ? Im good in both those departements.
Help would be appreciated
Thanks
Thanks
