Ok, so I have been using Windows 8 Enterprise (Release) for about a week now. I got it on day 1 from MSDN. I got to say that I’m already used to it and it does not affect my workflow at all.
Yes, it boot straight to the metro screen, but a quick tap on the Esc key and it goes to the desktop. To tell you the truth I prefer it going to metro right away anyway because when I first login the first thing I need to do is open up a app, like Outlook. So really it saves me a click. Now, I did uninstall all the metro apps, and pinned my apps to the start menu and arranged them to my liking.
My Metro screen: https://skydrive.live.com/embed?cid...=29DA2B1531333A91!829&authkey=AFTMQGSAiZWN1Is
The search is nice too how it sorts it by Apps, Settings, and files is really intuitive compared to searching for stuff off the Windows 7 start menu that gave it all to you in a list that was as small as the start menu itself.
The only con, I think is the time it took to get the metro screen to work like I have it, it’s not something a common end user is going to pull off themselves without getting frustrated.
Its fast, everything works, I welcome metro, did I mention it fast?, hyper-v works wonderfully, it didn’t take anything away we had in Window 7 (that more than you can say about OSX and popular half brew Linux distros.)
