RogueTadhg
- Dec 14, 2011
that speaker placement....
Sorry for being ignorant, but what's the point of a setup like that?
While these setups have no bezels, they do have serious trade offs. Like the obvious image transition and image disparity. Not to mention having to sit in the "sweet pot" at all times. Found that out the hard way with my 3x FW900 fresnel setup. Not to mention look how far he is sitting away from the Image. Just isn't worth it. My attention has moved away from eyefinity and all of its problems and more towards 4k single displays.
Thanks for chiming in Vega...what are you running these days?
uhhh....doesn't that huge and ugly box count as a bezel?
http://www.desktopreview.com/default.asp?newsID=868
http://www.youtube.com/watch?v=jxnqvX37GQ8
They did already. Just never became much of anything.
If they made a 32:10 ish monitor with 1200p for under $1200 I guarantee it would be a hit as long as it hit all the check boxes that gamers need.
A 27" catleap at 132 Hz. Probably will run that for a while as I don't know how well a 4k monitor would work for me running at 60Hz.
2X u2913
I think it would work out better having 2 monitors below, 1 above, and having them all mirrored on a single mirror, to get rid of the mirror lip.
I am interested. Will this work for two monitors?
Why is the middle on horizontal and the two side vertical? Can you use 3x 27 " 2560x1440 monitors?
