Boygenius32
- Aug 16, 2014
I opened up my gpu block for my first annual teardown, and the nickel plating is peeling from the copper block. How should I proceed?
I came expecting an EK block... I found a... I don't what block that is.
I would say try to remove as much of the flaking as you can. I'm not sure if there's something you can use to chemically remove the nickel plating.
Thats a Koolance block, This one. I called their tech support line, and the tech said he would forward the pictures to the block designers. Not sure if I should be pursuing replacement or just scrub off the flakes.
They said it's not covered under warranty, as the delamination was apparently caused by my copper sulfate dead drops. Apparently the block will work just fine without the nickel, so I'll just scrub at it.
Should've just told them you were using their premixed coolants. Under no normal circumstances should a properly plated nickel block flake like that.
When you email any water cooling company with nickel flaking problems, always tell them you ran distilled water 24/7 with nothing else. They will instantly deny you if you say anything but distilled or some premixed bullshit that they sell. Period.
I refuse to buy any nickel plated cpu/gpu blocks anymore, not worth the hassle.
