Nice LAN case thermaltake
Bad design.......power supply is right over the CPU area........that's going to limit you on beefy heat sinks.
The case is not as small as it looks. Its 18 inches deep (length). My V354 is only 16" deep (length).
It's just the LANBox with new "aesthetics"
I have a LANBox, while I find it neat, it is a pain in the ass. Like mentioned above, you are limited to the HSF you can use... The biggest that fits is something like Gemin II cooler. http://www.newegg.com/Product/Product.aspx?Item=N82E16835103046
It's big plus is that it sits on your desk without being a big hulking object.
Cable management is a nightmare.. in the end, I just have a big pile of cables.
