nForce4 SLi vs nForce 500 Series??
xenithon
Hi all. I am builing a new AM2 system and it needs to be first-and-foremost solid and stable. I can get for around the same price, either an nForce4 SLi motherboard (Asus M2N4-SLi) or the nForce 570 motherboard (Asus M2N-E). Is there any particular reason to go for the nForce 500 series over the nForce4 SLi series? Bear in mind:
- I won't be overclocking
- do not LAN/game much (so won't use the teaming and other associated features of the 500 series)
The reason why I am hesitant of the nForce 570 is that everywhere I have read, they are not known for being the most stable and are RAM-fussy (and also since I have very limited options, so the Asus are the only boards worth considering here). Is the nForce4 SLi (M2N4-SLi) a better choice for my setup? More stable?
Cheers,
X
The 5 series might get you a little more performance at stock speeds, but probably not noticeable. The NF4 is very mature by this point and should provide you with a very stable computing environment. Since you're not OCing and don't see yourself using the extra features, get whatever is cheapest. You aren't shortchanging yourself going with the NF4.
Thanks for the prompt reply. You wouldn't happen to know if the M2N4-SLi is compatible with the Scythe Ninja Rev. B, would you :D
Lol...nope :). I haven't tried any AM2 boards yet. I'm looking at possibly making myself a little brisbane 3600+ system to play around with but haven't got there yet.
Thanks again for the prompt reply. I needed to import the cooler as I want to run it passive, hence the question about the Ninja. Worst case scenario is that I will sell it and get something else - I'd rather change cooler to match the mobo rather than the other way around :cool:
And yes, from everything I have read, there is nothing special I would be missing. I do not need the 6xSATA ports, 4 is sufficient. And I read that the nForce4 SLi supports NCQ, so that covers everything I need.
