nForce4 Chipset Drivers
What do you install with your nForce4 Chipset drivers?
  • All of 'em
    Votes: 10 27.8%
  • All but the IDE driver
    Votes: 4 11.1%
  • All but the audio driver
    Votes: 9 25.0%
  • All but the IDE and the audio driver
    Votes: 7 19.4%
  • Something else (please post)
    Votes: 6 16.7%
  • Total voters
    36
Oline61
What do you install with the drivers. I do all but IDE and Audio drivers, because I hear bad things about the IDE drivers, and my MSI Audio driver's sound much better than nVidia's.
IDE is useless and most boards have Realtek based solutions anyway. No need for IDE or audio (or the hardware firewall for that matter ;) ).
Well, I don't install the audio drivers because I have on-board audio disabled in place for my Audigy 2.
I do install the IDE drivers (although I have heard the same bad things) because I have never had a problem with them since nForce2 and they seem to increase drive benchmarking a bit. If, for a second, i thought they were the least bit unstable from my own experiences I would not install them. That just hasn't been the case though.
With my current rig, at first I didn't install the IDE or the audio drivers. I did try the firewall, but it was giving me fits. Right now, however, I am running with all except the audio driver and the firewall installed (remember, I have the onboard audio disabled, and my Windows drive is the only drive on any of the nForce4 SATA ports; thus, it did not hurt when I installed the NVIDIA IDE driver which on my rig only the SATA driver got installed).
I install all but the firewall and net manager.ive never had a problem with the ide drivers on any n/force board,2,3,or4.the latest ide drivers 6.70 bench slightly higher than the microsoft drivers.this is the first time ive seen a difference.i would like to know why the ide drivers give some people fits.its hard to pin down.ive used all kinds of configurations and never had a problem.I like the nvidia audio drivers and control panel better than the realtek drivers and software.
Sometimes the IDE drivers keep Windows from booting correctly. I've had issues on NF2 boards with DVD playback being very jumpy.
I install only smbus drivers and ethernet driver. Installed sata raid driver on install.
I don't use the Nvidia firewall drivers. But I do find Nvidia audio to be immensely better than the Realtek drivers. Much more control and better sounding with proper setup. I couldn't get Realtek to sound decent no matter what settings I tried...
the nforce drivers for my mobo actually ended up being much nicer than the ones that are provided by gigabyte, so i install everything now, i've heard bad things about the IDE too, but i've never had any issues so i see no reason to use anything else
All but the audio driver because I'm using an Audigy 2ZS Platinum. Install both sound cards and it will conflict resulting in very strange behavior. It took me a while to realise what was going on, but I realised that the onboard sound was conflicting with the Audigy 2. As for the rest of the drivers, they work great. No problems whatsoever.
well normally you should always disable from the bios (not trough drivers) onboard sound if you'll use a sound card.
As far as nforce drivers go i install all of them and i never had any isues except with version 6.66. I understand that some people have issues with their IDE drivers but from my understading to enable NCQ you need the nvidia drivers since the built in windows ones do not support it.
