nForce
bug
04.12.13
nForce5 (2Q2005) two chip design (C19 + MCP04 [IBM fab]) supports two PCIe graphic ports (SLI) and DDR2 (533 or 667MHz) memory, 1066MHz fsb 775-pin LGA P4 and 939-pin A64, USB 2.0, Gbit ethernet, Nvidia does not like to release info about "future" products... http://www.theinquirer.net/?article=20037 http://www.theregister.co.uk/2004/12/08/nvidia_crush_intel/
nForce4 (after Intel lost 6% of it's chipset marketshare lead to VIA, SiS and ATI) cross licensed (Nov 2004) Intel with Nvidia so Amd nolonger had exclusive braging rights. SLI (Scalable Link Interface) (two GF 6600GT or higher) and two other mobo variants. x16 agp, four sata and four parallel ata drives with raid (0,1,0+1,) Gbit ethernet, 775-pin P4, 939-pin AMD cpu, pci express fsb (1066MHz [266MHz quad pumped,]) high-definition 7.1 audio, .. Ultra model supports sata2 (3Gbps,) ten USB 2.0 ports, hardware firewall,
NVIDIA's nForce3 launched March 2004. And was largely to support AMD's 64bit cpu. The nForce3 MCP chipset (Media and Communications Processor) was set to release in six variants. 133MHz PCI bus, integrated Gbit ethernet and firewall, (limited Linux support,) four SATA150, eight USB 2.0 ports. http://www.bit-tech.net/feature/35/
nForce2: (Nov 2002) "gamers" platform with ATA 133 ide & sata controllers, USB 2 & IEEE 1394a (firewire) support, dual-independent 64bit DDR memory controllers, x8 agp (2.1 GB/s,) 3D integrated audio (Dolby digital 5.1,) firewall, gigabit ethernet, twin bank memory architecture, raid (0, 1, 0+1,) HyperTransport bus interface, 333MHz fsb,
nForce1 (2001) for the 21st century, Nvidia knowing computers are used for applications other than word processing and spreadsheets intend their nForce chipset mobo to include broadband and 3D audio (Dolby Digital 5.1 [from MS xbox,]) IGP Northbridge (runs memory, video & processor functions,) MCP (Southbridge) supports pci & ide with HyperTransport (HT) communication AMD specification (allows for 800MB/s communication between MCP & IGP [3X faster than pci,]) memory controller (TwinBank Memory Architscture) offered 64bit or 128bit DDR (200 or 266MHz) interface (4.2GB/s bandwidth,) 10/100 Base-T networking / 56k modem support and USB interface. An optional integrated video processor (GF2mx) or AGP (?x6 speed) support for x4 agp slot gpu. (This was when other integrated mobo were doing 500 in 3Dmark benchmark & the nForce420 was doing +2500.)
Umm, I checked the inquirer and nowhere does it say that the nForce5 (which hasn't been officially designated as the name)supports A64 939. The only thing that it states is the the intel version of the nvidia sli chipset will requirer two chips on the motherboard, where as the AMD solution only needs one (AMD a64 integrated memory controller really kills the need for a northbridge.)
The only other info with a AMD name in front of it is basically stating that AMDs hypertransport tech will be used to connect the two chips needed on a P4 nforce implementation.
There is no 1066FSB A64s, and AMD has shunned the use of DDR2 for the time being. Which is fine by me, what with the high latencies and costs associated with the technology. That and AMD would actually have to make a change to the chips because of the need for a new memory controller. (Some speculate the new 90nm support this tech, but I'll believe it when I see it)
You may want to correct your original post
04.12.14
One reason for the Intel, Nvidia cross license was to bring Intel's 1066MHz fsb into the nForce chipsets and allow DDR2 memory in the nForce5 chipset platforms instead of just relying on AMD's HyperTransport (2002.)
AMD is shifting the majority of it's future cpu to the 939-pin models, so, the nForce5 would support that AMD 939-pin and the Intel 775-pin LGA cpu inserts.
The question is if Intel's two-way serial PCI Express (I/O interconnect bus) architecture specification besides the 'single-wide' (8 lanes) and 'double-wide' (16 lanes [higher-performance applications]) modules will replace the conventional 66MHz PCI local bus standard (1992,) and utalize the 266MHz fsb Intel quad pumps to 1066MHz.
So far i can not find any mention if the A64 will have ddr2 (200, 266 and 333MHz bus frequency) memory controllers much less the dual-core A64 next year and what trade off higher DDR2 latencies will demand.
So, you are saying that one chipset is going to support two fundamently different platforms such as the Netburst and the A64 platforms. Yaa, right. I will believe it when I see it.
