OFaceSIG
- Aug 31, 2009
Which is the better unlocked phone, Nexus5 or MotoX? Opinions and facts will be appreciated .
Price isn't a concern and I specifically do not want a Nexus6. Too effing big.
Nexus 5 battery life is terrible and there's nothing you can do to fix it, other then keep it tethered to a power source whenever possible.
If price isn't a concern, may want to see if this Droid Turbo will be available unlocked (which it will be from Verizon anyways) and supported by your carrier. It's basically a smaller Nexus 6 or a beefed up Moto X (esp in the battery) depending on how you look at it.
Sure there is, update to Android L(ollipop - hate that name).
Makes a significant difference in battery life as reported from a couple friends with them and every tech blog soon after the preview was available.
Where have you read that it will be unlocked?
I'm running the dev preview that was released on Friday, sure it's a tad bit better, but nothing significant.
It's pretty significant. Sucks you're not seeing it for your usage patterns though. My friend on his N5 noted about the same percentage (30-40%) increase in battery life on his N5 and he's a moderate-heavy user.
I don't really use it for browsing, basically I just want to get emails on it, that's my biggest usage. Without a sim in it since I'm just using it for testing, it thinks it's good for 7 hours with little to no use just sitting on my desk.
Currently nothing shows in the battery stats except cell standby. There is a battery saver setting that reduces background data but that will throttle email and messaging if you don't have the app open. Doesn't do me a whole lot of good since all my alerts come in through SMS or email, wouldn't be very useful as a work device without them.
One thing is, the dev preview doesn't have the exchange apk installed, you have to install it manually after the fact. I'm not sure why, maybe they're trying to tweak that as well for better battery performance.
Something is seriously wrong with your phone.
My N5 streams music at least half the day to a bluetooth headset, while syncing email, while updating RSS feeds, while on wifi, and I have at least 30-40% battery left after a full work day.
