- Nov 27, 2006
TechNewsWorld has an article about the promises of graphene, which is hoped to take over where silicon leaves off when shrinkage hits its limit. In the lab, it certainly shows promise as a flash-memory replacement.
As he began testing graphene as a memory device, [Rice chemist Jim] Tour found that it worked better than silicon-based flash memory in a number of respects: It leaked less current, it generated very little heat and it operated in temperatures from minus 100 degrees Fahrenheit to nearly 400 degrees.
