Next Firefox Update to Auto-Update Flash Player
Terry Olaes
I Used to be the [H] News Guy
Mozilla is rolling out an update on Tuesday that will scan for and automatically update obsolete versions of Adobe’s Flash Player. PCWorld reports that this is the first of several updates designed to bring third-party plug-ins up to date to reduce malicious attack vectors. I thought FF already automatically updated plug-ins but apparently they only check extensions and add-ons, not plug-ins.
Christopher Blizzard, a Mozilla evangelist and former member of the Mozilla Foundation's board, spelled out in greater detail just what Mozilla wants to do. With the release of Firefox 3.6, now scheduled to ship in early November, the browser will check for newer versions of plug-ins through the same mechanism now used to check for updates to any installed Firefox extensions or add-ons.
I like that 3.5 doesnt have to be shut down to install flash, quite an annoyance in my field of work
good!
its mostly 3rd party stuff that leave other products exposed
beyond flash, the other stuff they're planning on updating (fta: Apple's QuickTime; Adobe's Flash, Shockwave and Reader; Microsoft's Silverlight; and Sun's Java.); this is pretty big, although the people I know personally that this would help tend to ignore update alerts anyways..
As long as they don't force a Java update on me, I'm fine and want to stay with Java 6.10.
I also noticed in the bug list, cpu utilization for sites with form data is buggy and being fixed. I'm wondering if this will bring fixes to those who have cpu utilization problems with firefox.
I'll have to remember that, if I ever come back to FF. I am trying Chrome beta 3.0.195 for a month and really liking it.
I use both, Chrome's nice for running stuff like GCal and GMail as desktop apps, for usability purposes as well as to keep 'em isolated from my mess of Firefox windows/tabs, heh.
I think FF should be set to automatically install plug/extension updates AFTER you close the browser. That is, you run Firefox, if it detects updates it then warns you when you close firefox. This way, you can set it to shut down the computer.
I think its a brilliant move, hopefully IE will move that way as well. My only grip with FF now is that it eats huge amounts of memory, I only have: Xmarks, IETab, Gmail Notifier as extensions. Often when I close FF, I get a crash which is very annoying.
That had been happening for a while on my sister's system previous to 3.5, after the update it stopped happening... Not sure what caused it but a re-install might fix it, nothing else changed on the system between updates.
Now all they need to do is make Firefox warn you of important Adobe Reader/Acrobat updates also. Or better yet have Firefox recommend Foxit instead. Or betterer yet make the PDF file format a crime against humanity. :p
There's a lot of good reasons for the PDF format to exist... Not as many for all the added complexity they've added tho.
This is not going to end well.
What is it about Java 6.10 that is better than the current 6.16, and is it more important than the many, many security fixes in later versions?
I know for a fact that JRE 6 build 14 and beyond breaks what is working with JRE 6 build 13 and prior for an application we use at work. It breaks it for administrators (specifically, password reset), which a non-admin user wouldn't encounter.
For home/personal use, however, I haven't had any problems using the latest and greatest.
firefox should come with NOSCRIPT
swear i havnt seen a single tracking cookie or anything else ever since installing that plugin
Whatcha gonna use instead, Silverlight? :p
Well, because of HTML5's audio and video tags, Silverlight and Flash are approaching superfluousness. The only legitimate reasoning for Flash I can think of is now browser games, and Java may be better for that.
There's not much worse than a website made of Flash!
I dunno, Silverlight has some pretty impressive HD video capability and uses very little CPU as this demo shows. http://www.iis.net/media/experiencesmoothstreaming I can actually run that demo full screen at max 2750kbps and get 24fps while Folding@Home is running on both the CPU and GPU.
Doesn't No Script break usability w/ many sites that use cookies, such as Amazon, banks, etc.?
Nope, just allow the correct domains (which will show up in the drop down list when you visit the site) and it works like a charm. From there on out you will never have to allow the domain again (unless you choose to temporarily allow).
Sweet! I'm going to go grab it now ...
