I recently bought a Nexstar 3 ide enclosure to use with a spare 80 WD drive I have. its a WD800 7200rpm model. Nothing fancy.
No matter how I set the jumper, I can't seem to get windows to recognize the drive when hooked to the enlosure. It works fine when I hook it directly to the computer, and the USB enclosure is recognized by windows by itself. I don't have any other drives to test out, and my next guess is to try a different cable inside the enclosure.
Has anybody else had any issues with the Vantec Nexstars? I was under the impression from reading about them that they are good units. This is the first time one of these enclosures hasn't "just worked" for me, and I'm almost out of troubleshooting ideas.
Thanks!
Thanks!
