Newly assembled PC shuts down after a few seconds
fubak
I just assembled a computer using parts of 2 different PCs. The mobo, cpu, and memory were from one and the rest from the other. I had to reseat the cpu and cpu fan. However, I didn't use fresh thermalpaste. :( Could this be what is causing it to shut down after 5 seconds of being on? I don't hear any beeps or BIOS posts or anything.
The motherboard is an MSI board. And it's a AMD XP2000+ CPU.
...yes. You need fresh thermal interface material in there or you'll toast your CPU.
Keep in mind that "plain old" silicone based thermal goop you get from Rat Shack will work in a pinch and is actually within a few degrees of the "designer" brand thermal compounds you can buy. It's not as bad as some would have you believe; quite acceptable, actually.
The lack of BIOS beeps are somewhat troubling, but I sure as heck wouldn't try to troubleshoot that until I had my cooling squared away..... :cool:
Good Luck - B.B.S.
well it's very possible that the CPU is overheating - make sure the HSF makes good contact with the core.. touch the heatsink and see if it gets any warm.. do you get anything on the screen?
I'm just going to goto CompUSA and get some there.
Any recommended way I should clean off the old thermalpaste or should it just wipe off easily?
Nope, nothing on the screen at all. Hope I didn't toast it already :-/
Unlikely, but possible. You should get beep codes with a dead CPU.
You did hook up the PC speaker, right?
Don't worry, you won't see anything on the screen until the computer has been on for more than 5 seconds anyway. Your CPU is overheating before then.
Yeah, it beeps when first turned on. Like as soon as I hit the power button.
The beep corresponds to the actual error. If it's a siren, it's overheating and/or the CPU fan is not spinning (which could also be caused by it being plugged in the wrong fan header). Check your motherboard manual?
Also, did you clear the CMOS?
i razorblade it off of the heatsink and off of the proc.... just be very very very careful... did i mention be carefull?
I had a similar problem with mine. I think it was because my fan sensor shuts the computer off if the CPU fan is not spining at the right speed, some safety procedure. I just switched the CPU fan connector cable from CPU Fan 1 socket on the motherboard, to CPU Fan 2. Not sure why mine has 2 sockets for 1 fan, but if yours does give it a try
