Newegg refurb mobos?
MattsOnlyHope
I'm looking for an A64 mobo and noticed for the amount of money i can spend I can get a better deal from newegg if I bought a refurb. Does anyone have an experience with newegg's refurbs?
There's a moderately long thread on Newegg refurbs if you do a quick search for it.
I just bought my k8n neo 2 plat from newegg. The exact same board was half the money. I couldnt do it. as u know your mobo is the heart of everything. I just didnt want any probs. You would probaly be ok. Its easy for me to say that with someone else coins. I know this doesnt help you any. sorry.
As someone else said, long thread about this already, search in the forums. To make a long story short, refurbs are often missing cables, manuals, backplate connectors (for stuff like USB/FireWire/Audio) and other accessories, and are often returns where someone might have tried things like extreme overclocking, etc. You're making a big gamble. I myself wouldn't do it, a bargain isn't a bargain if it doesn't work right or doesn't come with needed accessories you'll need to buy later.
I bought a MSI 865PE refurb from NewEgg. As people have said already, only the board was shipped without any accessories. Some, however, have received complete retail kits. It depends on the luck of the draw.
If you buy a refurb, be careful on what you buy. I chose a MSI board because I have had experience with their RMA service and know they will warranty the board for 3 years from the original manufacture date.
I got my motherboard refurb from Newegg. I have had no problems with it. I think mine even came with all of the accessories other than the I/O shield.
that's what I am afraid of.. I don't care about anything "but" the I/O shield.. which means I would have to call the manufacturer and either wait until I get one... or tear apart the computer when it comes in to install it.
did yours have the i/o backplate?
I picked up a socket 370 mobo for a good price on newegg refurb...no I/O shield though and it's a special one...that was the only downside, mobo works great!
Mark099 said:
No, but it's not really needed.
I had a case with a missing plate before... it messed with the airflow like crazy and dust bunnies came out with a vengeance. :) I also don't like applying pressure to the i/o plate w/out some sort of support.
Asus also has a 3 year warrenty with thier refurbished motherboards but that did not stop Newegg from sending me 2 bad boards back to back. It's really just luck of the draw.
If you like a good challenge then I say buy yourself one. If you don't like headaches from trying to figure out what the manufactor did not fix or if they simply reboxed a bad board then buy yourself a new motherboard!
I think his point was, he could send a bad board back to the VENDOR, not to NewEgg. In your case, ASUS has a lousy history with RMA's according to forum posts I've seen, so you could probably send it back to them, but it doesn't give you a guarantee. He was stating he could send his MSI board back to MSI, rather than to NewEgg.
This doesn't change my original opinion; I agree with you that I wouldn't buy a NewEgg "refurb" mainboard.
i have bought many refurb boards from newegg, all ASUS brand... i have never had a single problem with them not booting etc. the few times i have had to RMA w/asus has always been a good experience
Buying refurb is a gamble. You either end up with a great deal, or a big head ache. I've been through both circumstances.
Asus has THE worst bios of any manufacturer. They are constantly releasing a new bios almost weekly. You probably got a couple of boards that somebody flashed the bios and killed them,then sent it back for replacement. Since New Egg just sticks the returned boards in a box and sells them for refurbished,since they dont test them you take a chance. I also recieved a refurbished Gigabyte board that wouldn't even post,im sure someone flashed the bios and killed it.
I returned it and bought a new one instead.
