Newegg Q9300 OEM $299
just check your mobo's website. most p35s with a bios update, and most x38 and 48s by default, probably 780 series as well.
I don't think it will work on a 680i chipset... from what I've read, 680i does work with 45nm dual cores, but not 45nm quad cores... Correct me if I'm wrong...
It is supposed to be $250 though and does beat the Q6600 Stock for Stock by 7%.. Cant complain there.. Plus, You should be able to get 3.4ghz out of it on a good board.
I'd much rather make up that 7% by hitting 3.6 with a q6600 like I am right now, at lower FSB speeds
darn right. too mucha money for what is an iffy proposition at best. only for those who need to be the first kid on the block. q6600 has more cache, higher multi and proven oc. for $100 less.
I bought one to retire this X2-3800.. Ill let yall know how it turns out.. (Bought a P35 Board for $80 to go with it and some DDR2-800).
I agree after what I saw of one comparative test, when gaming the Q6600 had a better benchmark result than the 9300 and the 9300 was tricky to overclock according to the same review.
due to the Smaller Cache and 45nm Process, it consumes considerably less heat.. One site calculated with the average price of electricity, you will save about $5 per month if you leave your machine on 24/7 over a q6600.. So $60 per year..
No worries. Happens to the best of us. Although, if I could get a proc that ran on heat instead of producing it...lol
I hear ya.. reminds me, doesnt someone now make a Sterling Engine Fan? the heat the Chip makes power the engine that runs the fan the cools the CPU.
