http://www.newegg.com/Product/Product.aspx?Item=N82E16820249021
is this the best price yet, so tempting, tax in CA that's suck
Over $1/GB seems really high compared to some of the recent 256 GB SSD deals.
Considering that the Crucial M4 & Samsung 830 have been well under 200 this isnt a hot deal at all.. it may be a better drive, but not enough better to pay much of a premium.
This is the pro version, not the regular M3.
This is probably the best SSD you can buy, but not worth the money difference over a samsung 830, crucial m4, or sandisk extreme
What do you mean by "best"? Not being funny, just wondering what makes this SSD best (leaving out the price premium).
Read the conclusion from AnandTech's review:
http://www.anandtech.com/show/5851/plextor-m3-pro-256gb-review/10
After reading the conclusion, then rereading it, I fail to understand what exactly would make this drive worth the price premium..
To me, the only advantage is the 5 year warranty, but the M3 itself has that, costs less, and to performs exactly the same..Sure, if you are a Mac user, then the power usage @ load is a bit better then the Samsung 830, but if you aren't, then I still dont see the advantage. I would take a Sandisk Extreme, and use the extra money toward something else.
I agree with everything you said except instead I'd pay the premium for an Intel 520 or just pay $40-$50 less than both and get a Kingston Hyper 3k or Samsung 830. Not seeing the awesomeness of this SSD other then warranty.
That said, it makes me wonder when the SSD's are coming out with the newer Marvell 88SS9187 controller? Or are they already out in newer SSD's, just not the Plextor M3 Pro (like Anand stated in the conclusion)?
QFT. This price getting posted as a [H]ot deal makes me even happier I snagged an 830 for $190.With the Samsung 830s only costing what they are, I think it'd be silly to pay $260, even if it is a Pro version.
.I would either A)get the Samsung 830 (as you mentioned), or B)Stick with the Sandisk Extreme..it uses the same controller as the Intel 520, and 24nm toggle NAND, so it is a better deal to me then paying more for the "Intel" name..
^ those numbers largely mean nothing in regards to real world performance. They are just used for marketing and advertising purposes.
