i made a post in another section and was told to make a post here so here it is
this is the build i currently have on newegg
well if the prices of system builder have not come down in 6 months ill might buy from newegg just dont know what thermal grease to get i will not be overclocking my cpu or gpu at all
heres the build i have now on newegg
COOLER MASTER Storm Sniper or maybe a haf x or haf 932
ASUS P6X58D-E LGA 1366
Intel Core i7-930
CORSAIR XMS3 6GB 1600Mhz
CORSAIR Professional Series AX850
ASUS Xonar DX 7.1
evga GeForce GTX 460 1GB
Western Digital Caviar Black 6Gb/s
2xLITE-ON Black 24X dvd burners
ZALMAN CNPS10X Extreme
coolermaster fans 4x 120mm 1 140mm
fan cables link depot and HD power cables
OS 7 pro 64bit
all for under 2k
i probably dont need the big cpu cooler but i might OC in the furture
Edit/Delete Message
the only question i have is what is the best thermal grease for intel i7 and a zalman cpu cooler or a noctua one also i only need the computer for gaming at resolution of 1360x768x to 1920x1080 and dont need more than 4x aa so i figured that id only need a 460gtx 1gb at most the only game i have to play that i know of right now are guild wars 2 and diablo 3
my current pc is a
dell xps410 8600GTS 256MB vga and a intel Q6600 quad core 2.4Ghz and 2GB ram 375W PSU and i dont think i can play those games
if anyone has any suggestions on that i should change or add that would be helpful
o also its about 500 bucks more on digital storm and i get a 5 year warranty 3 year parts and a 1k watt corsair PSU
Intel Core i7-930
ASUS Xonar DX 7.1
OS 7 pro 64bit
all for under 2k
Edit/Delete Message
my current pc is a
