Video cards, motherboards, RAM have all come and worked without issues for me. YMMV though.
Ditto (almost) for me. Got a K8N Platinum SLI on the cheap (got it for the SB Live! 24-bit, that was a mistake). I haven't had a single problem with the board, but it came bare as can be, not even a connector plate (USB, keyboard/mouse, etc.)If you think you can take the risk, go for it. But if it were me, I'd probably keep it where I can make sure it works good from the start (i.e. ram you can run MEMTEST on), or I have a way to make sure it works to my expectations, 1 of the 2
As a system builder i order alot of motherboards and ive ordered many of these off newegg over the years...Ive had maybe 3 out of 50 that were bad and all were replaced or refunded within the 15 days..I make sure i have all the other pieces before ordering so i can put it together within the first couple of days and test it out...Some came with accesories and some not but i would not hesitate to order one if i was trying to save money...I have an msi am2 board coming right now and it saved me 50 dollars.
