Hey guys, I am kind of a newb with motherboards. I am looking to see if I can upgrade my cpu with the motherboard I have. I currently have a Pentium D 820 (2.8 ghz). My motherboard is this- Intel d945gcz. Thanks
Unfortunately, Intel didn't make that board compatible with current Core2 CPUs, so you're stuck with Pentium Ds. Seeing as how you already have an 820, theres not much left for you that would really make a big impact.
What do you do with your system?
What is your budget?
What RAM do you have?
What are your other components?
Do you have a Fry's near you? You can get a Pentium Dual Core (NOT Pentium D) E2180 2.0Ghz and ECS 945GC motherboard combo for around $88 from Fry's. BTW, a 1.8Ghz Core2 architecture chip would be as good as a 3.73Ghz Pentium Extreme Edition 965.
1- Mostly gaming
2- Not sure, maybe $300
3- 2 sticks of 512mb ddr2 dual channel, plus 2 sticks of 1 gig ddr2. 3 gig total
4- pentium D 2.8, NVidia 7600 GT, 3 gig of ram
5- No, the closest one is 50 miles. I thought the Pentium D was a dual core processor.
it is dual core, but an older, much less efficient, and less powerful architecture. kind of like 2 pentium 4's scotch taped together, just to compete with amd x2 until core 2 duo came out.
for $300 soon you will probably be able to get a quad core and mainboard.
"Pentium Dual-Core" is the name of the new lower end Core2-based dual core chips.
"Pentium D" is the name of the old higher end Pentium4-based dual core chips.
A Pentium Dual-Core E2160 will perform the same as the highest end Pentium D, which is the Pentium Extreme Edition 965.
What games do you play?
What size monitor do you have or plan on getting?
What resolution/settings do you game at?
1- Mostly racing sims. Rfactor, Gtr2, and Race 07. Also fps. I play a lot of fps too, but recent I have been playing those on the 360.
2- It is only 17" I would like to upgrade that too, but its not too big of a concern right now.
3- 1280 x 1024
My current system plays the games I mentioned above pretty good. Although I do have to make a few sacrifices with the eye candy. I do play them all in dx 9, at 1280 x 1024, AA is set at level 1 or 2, Most of the visuals are set to full accept for Reflections and shadows. Shadows seems to be the biggest killer in fps for my system. The fps that I get usually averages around 40. I do see peaks anywhere from 70 to 100 if there are no other cars near me. However when there is a lot of traffic I will see it dip down into the upper 20's. Thats where the problem is. All the games seem to run fine if it does not drop below 35, but below that it starts to stutter.
Well, that sounds like a worthy investment. Do you think I would be able to play crysis if I were to upgrade to that card. My system would then be
Pentium D 2.8
HD3850
3 gig of dual channel Ram
