Programming, 2D/3D simulation , Web browsing, Videos
Approx 1000 dollars
3) Where do you live?
Odense (Denmark)
CPU, Motherboard, GFX, RAM, HDD (for OS)
Samsung DVD-burner, Corsair 520W PSU, CoolerMaster Stacker, 4*Western Digital Green HDD's
6) Will you be overclocking?
Maybe
2*19" + 1*32"(TV)
Within 2 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Firewire (USB3 and SATA 6Gb/s is nice to have)
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
No, using linux, 32-bit
Hey, planning to build myself a new workstation for home since my current is placed at the university for a long term project.
Since I am from Denmark, then prices and availability differs a bit, but I will start out with my own thoughts for a build (using american sites to ease language differences)
CPU - Intel i7 2600K http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070&cm_re=i7_2600k-_-19-115-070-_-Product
Motherboard - AsRock Fatal1ty P67 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157240&cm_re=fatal1ty-_-13-157-240-_-Product
RAM - 4GB Crucial Ballistix 1600Mhz http://www.newegg.com/Product/Product.aspx?Item=N82E16820148325&cm_re=crucial_ballistix_ddr3-_-20-148-325-_-Product
HDD - OCZ Vertex 2 60GB http://www.newegg.com/Product/Product.aspx?Item=N82E16820227550&cm_re=ocz_vertex_2-_-20-227-550-_-Product
GFX - Sapphire 5770 FleX http://www.newegg.com/Product/Product.aspx?Item=N82E16814102906&Tpk=flex%205770
COU Cooler - Scythe Mugen 2 http://www.newegg.com/Product/Product.aspx?Item=N82E16835185093&cm_re=mugen_2-_-35-185-093-_-Product
The Sapphire 5770 FleX enables me to use the HDMI and two DVI ports simultaniously, which is nice with all my display and I have read about some problems with using a DisplayPort to DVI adapter, so I am trying to avoid that solution.
While the AsRock Extreme6 provides the same features as Fatal1ty, then as an engineer does the heat sinks look better and more efficient on the Fatal1ty, making me interested in throwing a few more bucks for it.
But I look forward for your thoughts.
Regards
Sebastian Aslund
Approx 1000 dollars
Odense (Denmark)
Maybe
2*19" + 1*32"(TV)
Within 2 weeks
Regards
Sebastian Aslund
