Multithreaded programming (C++ and Qt4)
Around 1000-1300
Denmark
CPU+Cooler, RAM, Motherboard, Graphic card, SSD, Keyboard+Mouse, Headphones
Case: CoolerMaster Stacker
PSU: Seasonic M12II 520W
6) Will you be overclocking?
Maybe, depending on the increased compiling speed
7) 7) What is the max resolution of your monitor? What size is it?
Properly 2*19" 1280x1024
Within a month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
Primarily stability and reliability, secondary is flexibility and future use
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Will be running Ubuntu 64-bit with Gnome3
I have found the following components (using american shops for linking):
CPU: Intel i7-2600K
Cooler: Thermalright Macho
Motherboard: Asus Maximus IV Gene-Z/GEN3
RAM: 2x4GB G.Skill Ripjaws X 1866Mhz
Graphic card: Gainward Phantom GTX 560 non-Ti
SSD: Crucial M4 128GB
Keyboard+Mouse: Logitech MK520
Headphones: Sennheiser HD205-II
So any thoughts on this build?
Regards
Sebastian Aslund
Around 1000-1300
Denmark
Within a month
CPU: Intel i7-2600K
Regards
Sebastian Aslund
