Hi guys,
A friend of fine has asked me to build him a work station and I am shopping for parts. In our line of business we use mac pros, dual xeons and he wants something like it but cheaper. I told him that we can build something like that but better for a little over 2k.
He needs it mainly for maya and after effects so the more cores and ram the better.
I started searching on new egg and came out with this:
2x Intel Xeon E5620 Westmere 2.4GHz 12MB L3 Cache LGA 1366 80W Quad-Core Server Processor BX80614E5620 (290 dollars a proc)
1x TYAN S7002G2NR-LE Dual LGA 1366 Intel 5500 Tylersburg SSI CEB Dual Intel Xeon 5500 Series Server Motherboard (250 bucks)
2x Crucial 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) ECC Unbuffered Triple Channel Kit Server Memory Model CT3KIT25672BA1339 (240 bucks for all 12 gigs of ram)
2x Intel BXSTS100A Active heat sink with fixed fan (30 bucks a fan)
1x SAMSUNG 24x DVD Burner - Bulk SATA Model SH-S243N/BEBS LightScribe Support - OEM (25 dollars)
1x EVGA 01G-P3-1467-AR GeForce GTX 465 (Fermi) Superclocked 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video ... (230 dollars after rebate)....
he is not a gamer but i think a mid range game card will do, at work we have 8800gts on the mac pros and we are fine.. plus the card has cuda which might help him in the future... the quadros are overpriced and to get a old 150 bucks quadro i think he will be better served with a new mid range fast gamming card.
1x CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply (110 dollars)
im a little confused here, can I get a normal psu for the xeons and server mobo or do i have to get a special psu?
and then 2 500gb 7200 hard drives (prob samsungs cuz thats what i like) in raid 0 and prob a hitatchi 7200 deskstar 2 TB for back ups (arround 200 dollars).
so all for arround 2k... what would you guys change? does that psu work with the dual xeon/server mobo setup?, can i get better fans for similar prices (he is not going to OC), what about hard drives, i think the raid 0 setup for browser/work is good but can i get something faster (i know SSD is the way to go but too expensive/small)?
thanks guys, your help is really much appreciated,
Paulo
Paulo
