Hey all,
I'm looking to set up a new system for myself and not spend much more than around 800, less if I can. It's primary use will be for working out of the house for a call center taking calls for infomercials, although I would like ability to get into some gaming again. Most important is having upgrade capabilities, especially with the CPU, I want to make sure I'm getting the newest socket and best chipset for future cpus.
I prefer to use newegg for buying parts but any links to other sites will be most appreciated. This will be a completely new build with no older parts being re-used except for a 6month old 22inch monitor and a logitech wave keyboard.
I can buy parts in sequence over the next month or so and it does not need to be built tomorrow but I'm trying to have it finished in the next month or two. I have already purchased a Lian-Li case and it is on the way.
The most important thing I want to ask is power supply advice, what brands are the best to stick with and most importantly the ones to avoid. My first thought was to go with Antec Truepower as I have done in the past but I havent built a computer in almost 3 years now..
I stopped building pc's when I bought a power supply off craigslist(new sealed in the box), an x-power 800w, It was for a whole new system with over $1600 invested, hooked it all up and it turned on for about 2 seconds before it went to sleep forever... I really want to avoid this from happening again.
I'm trying to stick to Intel for CPU thats all I have ever used, although if anyone thinks I am making a mistake here and should go AMD let me know why, and am not sure if I want to go quad core or not so advice on this is helpful as well.
For motherboards the thing I am looking for help with is the chipsets that dont f**k up as I have bad experience with this in the past. (PT880 anyone?) Also I want to stay in the latest socket for my CPU so I will have that upgrade ability in 6 months or a year.
I guess this goes with the motherboard but are there any raid controllers to stay away from? I've only ever used silicon valley controllers. Are integrated controllers a safe bet now?
I dont need much help with HD's im looking to set up a stripe with probably around 500gb of space and there isnt much to look at there. The same could be said about video cards, I dont think I will use SLI or XFIRE yet but may in the future if anyone has anything to say about this it would be apprecaiated.
Memory is the same, I know what to look for there but any advice is helpful.
All help and advice is appreciated!
