New WHS build
kumquat
Windows Home Server build. File server, backups, etc.
Trying to keep the price as low as possible.
Here's what I have:
Antec 300 case + 380 watt PSU, $79.95
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129065
Athlon II X2 250 3 GHz 65W, $62
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103681
Asus M4A785TD-M 785G uATC Mobo, $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131406
Crucial 2x1GB DDR3-1333, $57.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148194
This is all the hardware I need. I have a couple of big SATA drives I'll be migrating from another machine to start this one, plus I'm ordering a 1.5 TB external drive for backups.
If there's anything else I should be considering to save a few bucks here, let me know :)
That 300 with the bp430 is not a good deal. The Basiq line is antec's lowest level offering and I would suggest getting the corsair 400cx or the earthwatts 380w instead.
You could go with the slightly cheaper Athlon II X2 245 for $5 less
Motherboard is ok, might want to shoot for one with sata6.0 and usb3.0.
Yeah as Shadowssong noted: The PSU is definitely low quality. And that combo is now $100 so it's an ever lesser choice. I recommend this combo instead:
$80 - Antec 300 Case + Antec EA-380D PSU
Significantly better quality PSU/
If you don't mind the loss of dual-channel performance, you can shave off $2 by going with this RAM:
$55 - Patriot 2GB DDR3 1333 RAM
