KSNIPPY said:will dvi actually make a differnence in picture quality though on this monitor?
Aleks said:On a side note, I tried my 360 connected via component and it looked horrible. The picture was all dark, nothing was clear it just didnt look anywhere near as good as it does with the vga cable.
Same thing happened with me, I was freaking out that there weren't any left, especially since I was fairly close to the front of the line. Luckily my friend who was heading to the DVD area saw a pile of them and grabbed twoGotenks326 said:All the monitors were placed somewhere else than they normally were, so I wasn't prepared for that. However, there were like ~15 of them and by the time I got in there only 1 or 2 had been taken
frappe33 said:I replaced a 20" NEC with the 22" Westy this AM. I love the size of the screen, but the overly bright screen was giving me fits. I tried using the contols in the panel to correct it, adjusting the contrast and brightness, but I couldn't for the life of me get it to look the way I want, which is the way my NEC looks. Dark deep, true blacks, definate whites without washing out the text.
To correct the issue, I went into the video card settings, the Nvidia settings that installed with the card and adjusted the settings here in the Color Correction section. Here is what is working for me now, hope this helps someone.
On the Westy itself:
Brightness - 70
Contrast - 70
In the Nvidia Color Corection
Brightness - 98
Contrast - 100
Gamma - 78
I made these changes and saved as a custom color profile fir each user on the computer. It now will auto load this at start up, and everyone is able to see the screen in all it glory.
As for other issues - No dead or stuck pixels, no lines, no edge bleeding. For $200 I am very satisfied. For $400, it would have gone back.
vudoo said:and the VGA will let you run 1920x1080 (according to the Xbox settings). The VGA setup is MUCH better.
buzzing noise when i turn down the brightness below 100.
got the PSP Plan for 24.99 (you *should* have 30 days to get it I believe if you didn't get it Friday),
JBrinley said:Is that the Best Buy 3 year plan?
Were do i go to get it?
~Joe
You can purchase Performance Service Plans (PSPs) or Product Replacement Plans (PRPs) for products you purchase both online and in our stores. Plans can be purchased during checkout or at any time during the product's return/exchange period (listed on the product receipt, which can be printed from My Account for online purchases).
To purchase a PSP or PRP in the store: Simply tell your Best Buy sales associate you'd like to purchase a plan, and he or she will provide paperwork for registering your plan when you check out.
To purchase a PSP or PRP online:
1. Add the product to your cart.
2. If a PSP or PRP is available for that product, it will be line-listed in the "Don't Forget" section. Click Add to add it to your order.
3. If you choose our store pickup option for your online purchase, you'll receive your PSP or PRP coverage details in an e-mail. Please print and save this email for your records.
Note: In some cases, Best Buy stores will have more PSP and PRP options than those offered online, with longer terms and different coverage options. Please contact your local Best Buy store for details.
To purchase PSPs/PRPs for items previously purchased: For both online and in-store purchases, please visit your local Best Buy store or call 1-888-BEST BUY (1-888-237-8289), and bring a copy of your receipt (you can get receipt copies online for BestBuy.com purchases).
Plans can be purchased at any time within a product's return/exchange period, which is listed on the product's receipt.
Gotenks326 said:Wow, I didn't notice that it had picture-in-picture as well. Sweet!
i'm using component with my ps2, and it's pretty bad...but it's good enoughxxkrnxstylezxx said:Okay. So I decided to take advantage of all the inputs even though I don't have Xbox or Playstation or anything.
I got a VCR that no one uses, connected it to the cable, and connected the component wire (Video, R Audio, L Audio) from the VCR to the monitor. If I put the monitor into "Video" mode, I can now watch cable television on my monitor. I'm not sure if other people find this obvious, but I found it pretty cool.
Of course, picture quality isn't amazing or HD quality, but it's definitely better than having to spend $100 on a decent TV Tuner. Now I'm trying to find out how to connect the audio to my PC so it plays on my PC speakers (Klipsch 5.1 ) instead of the monitor speakers.
I'll take pictures later when I get my camera back. As of now, I'm watching Mythbusters on my Westy and typing this on my Dell.
Question: Does anyone know what YPbPr inputs do? It looks like the components, and I'm wondering if I can improve the quality by using them...
omz said:i'm using component with my ps2, and it's pretty bad...but it's good enough
as for your sound situation, i used a simple splitter type of thing that came with my speakers (creative 2.1)
it allows me to plug in the R audio and L audio into a converter type device that i can directly plug into the audio input (where the wire from speaker --> sub usually goes)
You could just try using it with a VCR or something. That's what I'm doing and it works well.gepetto said:can you add a tuner to this lcd ?
You need a 1/8" mini to stereo RCA Y-cable. You can get them at your local Radioshack.xxkrnxstylezxx said:Yeah, that's what I was thinking...Split the wire that connects from my sub to the soundcard and plug one into the card and one to the monitor. But the problem is, I would only be able to plug into either R or L on the monitor, unless I can find a wire with 2 inputs on each side. Still a bit confused on what I need because of the R/L inputs on the monitor to the soundcard + sub to the soundcard.
Menu -> Misc -> PIP Menuxxkrnxstylezxx said:Really? I can't find it...
Gotenks326 said:I have some questions:
1. Who took off that plastic protective thing that was on the screen? Am I the only one that did?
2. What's the maximum HD resolution this monitor can support? It says it can only do 1680x1050 max (though that's not an HD resolution...), but some people are saying that they can do 1080i??
3. What's the difference between 1920x1080 and 1080i with this monitor? Why can component only do 1080i with this monitor, while VGA can do 1920x1080 (What can DVI do then?)?
4. Do you guys mean "Xbox" or "Xbox 360" (I don't know if you're referring to the old Xbox or the 360)?
5. Because this is a 16:10 monitor, I should only run 16:10 resolutions so that nothing is stretched and what not, correct? As far as 16:10 goes, I've only found the following resolutions that are 16:10 in Windows:
1280 x 800
1440 x 900
1680 x 1050
Is this what everybody else is getting for Windows resolutions?
6. Some people are apparently doing 1080i and other HD resolutions with this monitor and their game consoles. Are you guys getting black bars on the top and bottom (Because HD is 16:9 and the monitor is 16:10)?
7. If I connect this monitor to a cable box, can I view widescreen content (non-HD, I still have regular cable)? I always see in widescreen on the bottom of the screen on a lot of television shows, but I haven't been able to see the widescreen with this monitor yet (If I change the screen ratio to "full" the image is just stretched; I don't get the extra widescreen picture).
8. Are there supposed to always be bars on top when watching widescreen movies? Is this because the monitor is 16:10 or that sometimes movies are anamorphic widescreen?
Gotenks326 said:You need a 1/8" mini to stereo RCA Y-cable. You can get them at your local Radioshack.
Can anyone help me with my questions:
1. yes, it's just there for protection until you get it homeGotenks326 said:I have some questions:
1280 x 800
1440 x 900
1680 x 1050
Why can't it do 1080p and just downscale that?jbaczek said:2. 1680 x 1050 is the max resoluation, 1080i refers to an hd resolution which equates to 1920 x 1080 interlaced, the monitor will downscale this to 1680 x 1050 though
I'm still a bit confused then. It does 1080i but it squishes the image down to something equal to or under 1680 x 1050? How can you downscale something that is 1920 x 1080 to 1680 x 1050 without stretching anything keeping the same aspect ratio?jbaczek said:3. refer to #2, this monitor accepts any resolution up to 1680 x 1050 through vga and dvi, with the xbox 360 you can set it to output to 1920 x 1080 with the update, however the monitor downscales (i'm assuming don't have a 360 hooked up that way)
How is that possible? That must mean that things are being stretched to fit the screen, right?jbaczek said:6. no black bars, it fills the whole screen. for video and s-video inputs you have the option to set it to normal (4:3), full (16:10), or zoom (whatever that is, it looks like shit on everything i've tried)
1080p is 1920 x 1080, if what ppl are saying about the xbox 360 outputting 1920 x 1080 (1080p) then it can accept 1080 and it is downscaling itGotenks326 said:Why can't it do 1080p and just downscale that?
it distorts the image until it fits 1680 x 1050 so yes it does stretch the image to 16:10, or actually squishes it if it's coming from 1920 x 1080 which is obviously higher res than 1680 x 1050, lolGotenks326 said:I'm still a bit confused then. It does 1080i but it squishes the image down to something equal to or under 1680 x 1050? How can you downscale something that is 1920 x 1080 to 1680 x 1050 without stretching anything keeping the same aspect ratio?
yes, they are being stretched to fit the screen if there are no black barsGotenks326 said:How is that possible? That must mean that things are being stretched to fit the screen, right?
When it downscales to 1680 x 1050 isn't the aspect ratio already 16:10? Why does it change the ratio again?xbox 360 outputs at 1080p (1920 x 1080) ---> monitor downscales to 1680 x 1050 and changes the aspect ratio from 16:9 to 16:10, screen will be filled with the image, no black bars
No true 1080i/pGotenks326 said:So, this monitor cannot do true 1080i/p because it will just downscale it down and everything will be out of proportion? How good does 1080p look when downscaled to whatever this monitor downscales it to?
Also, it can't be downscaled to 1680 x 1050, right? Then that would mean that it would lower the vertical resolution by 30 pixels but lower the horizontal resolution by 240 pixels (Thus really out of proportion).
But when using the other inputs you can change the aspect ratio to the native 4:3 (I can play my Genesis/watch TV in 4:3 with black bars on the sides).jbaczek said:No matter what the source is or what resolution or aspect ratio you send to the monitor it will make it conform to the 1680 x 1050 resolution/16:10 aspect ratio. Witness this by changing the ouput resolution in your display settings to all different things. You'll see that it stretches it to fit and what-not.
