Ok I am currently running an E8400 @4.06GHZ on air. I would like to go water cooling and here is what I am considering.
My system:
E8400
Maximus Extreme
Silverstone TJ-07
My plans:
D-TEK FuZion Universal CPU Waterblock - 1/2"
D-Tek FuZion Accelerator Nozzle Kit
Thermochill PA120.3 Radiator
Thermochill PA120.3 Fan Shroud
Swiftech MCRES-MICRO Hi-Flo Reservoir
Laing D5 Vario/Swiftech MCP655 Inline 12V DC Pump
1/2" ID (3/4" OD) Tygon R-3603 Laboratory-Grade Tubing x 10 Feet (Not sure how much to get here fully)
Long Life Red Coolant Additive - 4oz. (like the red)
My goal is to remove the top grate on the TJ-07, remove the 2 120MM fans there and drill some holes into the grate to allow the hoses to flow through and of course support the structure of the radiator and then top mount it. I want to cool the CPU and the waterblock found on the motherboard into the res. I won't be cooling the video card at this moment since there is no waterblock system for the 9800GX2 yet. Is this an overkill or too much? Can someone recommend some good 120MM fans for the rad?
My system:
E8400
Maximus Extreme
Silverstone TJ-07
My plans:
