New Watercooled Rig!
Mullinz
It's time for another build and I wanted to get some second opinions or suggestions on hardware for my new build. I'm venturing into water-cooling more for a project than performance, but I would like this build to last me a good two years. So on to the questions!
Gaming, web browsing, photoshop, some 3D rendering/editing, and I would like to try folding.
Around $2800-$3000, doesn't have to include shipping, this also does not include the water-cooling parts I will be buying.
3) Where do you live?
Chicago
This is a brand new build so I'm not recycling any parts, so I need a case, RAM, CPU, Motherboard, GPU's (I want to SLI), SSD to boot my OS on, 1 TB+ Hard drive(s), power supply.
None.
6) Will you be overclocking?
Yes, I plan to get as high overclocks as I can while staying stable and not damaging anything. Hopefully water-cooling should help.
I currently use a 50in Pioneer elite plasma that I use, but I am most likely going to get a new 47in Samsung LED LCD tv to use.
As soon as now, or within two weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
I want RAID, SLI support, USB 3.0, SATA 6Gb/s, relatively friendly overclocking capabilities, built in audio, I would like bluetooth but that's just more for fun.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
No, but I plan on buying Windows 7 Professional 64 bit.
This is the basic build I have set out right now on newegg, but I'm certainly open to changes and suggestions.
Logitech G9x Black Wired Laser Gaming Mouse
Intel Core i7-2600K 3.4GHz LGA 1155 95W Quad-Core Desktop Processor
OCZ Vertex 3 VTX3-25SAT3-120G 2.5" MLC Internal Solid State Drive (SSD)
ASUS MAXIMUS IV EXTREME (REV 3.0) Extended ATX Intel Motherboard
CORSAIR Professional Series AX1200 1200W Power Supply
CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3
NZXT Phantom PHAN-001WT White Steel / Plastic Enthusiast ATX Full Tower Computer Case
EVGA GeForce GTX 580 (Fermi) 03G-P3-1584-AR Video Card(2x)
Western Digital Caviar Black 1TB 3.5" SATA 6.0Gb/s Internal Hard Drive -Bare Drive
Grand Total: $2,879.90
From what you've written so far, it sounds like you don't need such a high-end mobo unless you're planning on using four single slot cards in SLI/Crosfire. The mobo as part of this combo should be enough for you:
$505 - Intel Core i7 2600K CPU + Asus P8Z68-V PRO Intel Z68 Motherboard + Operation Flashpoint: Red River Combo
GPU wise, I'd go with GTX 560 Ti SLI, GTX 570 SLI, HD 6950 2GB Crossfire, or HD 6970 2GB Crossfire over a single GTX 580. Even the HD 6990 would be a better choice for the money.
HDD wise, that WD drive is overpriced considering that this Samsung drive performs the same but is cheaper:
$65 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
PSU wise, I'd go with the Antec High Current Pro 1200W since it's of higher quality for that not much more in price than the Corsair AX1200.
