Koreanzulu
- Jan 2, 2005
I've never used Intel before, but from the little Ive seen on the forums they are clearly the way to go. I'm looking to get an E6400, but Im not sure what else I would have to upgrade.
Right now I have a geforce 6800gt AGP, and 1gig of DDR memory. So it looks like ill have to get a new motherboard, and if there is anyway possible that I wouldn't have to upgrade my ram and my video card at the same time that would be ideal. Are there any motherboards that have both PCI-e and AGP? I think I would like to get DDR2 memory anyway, since I only have 1 GB. What brands of memory would you recommend, Im looking for around 2 GB, nothing fancy I won't be doing too much overclocking.
What is the best board for fewer than 100 dollars, Im not going to do too much overclocking, and am wondering if I can get PCI-e and AGP. I just want a reliable board. If I can't get AGP and PCI-e then what video card would you suggest, or should I wait for the DX10 cards? I haven't been up on things these past two years so I don't know if NVIDIA or ATI is the leader right now, I wouldn't like to spend more than 200 dollars on the video card and 200 on the ram if that is possible.
Or would it just be better to get a good board and upgrade my video card and ram, which I dont have a huge problem doing. If so what is the best board for my money, I dont need anything fancy, is there a difference when it says ddr533 or ddr800 standard, is that the maximum speed ram it will support? ie if my board only supports ddr667 should i only get 667?
I play some games, like world of warcraft and will probably be playing Vanguard when that comes out and do some video editing.
Thanks for the help =).
