New to building SFFs
smaug8821
Hey guys,
I'm trying to put together a "cheap" Shuttle for temporary use, until I get some more funds to put something nicer together. I'm moving into a medium-large sized studio apartment, so saving space is important. I'm concerned that this system isn't going to be able to be put together(video card fitting in case, PSU wattage, etc). Here are the things I picked out, if you see anything that will not work, or have any suggestions, please feel free to let me know; like I said I've never built one of these before.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16856101039 (note the 250W PSU)
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115052
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
Video Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127333
Thanks for the help.
Oh ok, thank you. You don't forsee any problems with the weak PSU and the setup?
None that I can see. Shuttle PSUs are supposedly very good quality units that can handle at least mid-range hardware.
Gotcha. Thank you for your help, hopefully I can get this together within the next few days. :)
Everything else looks good
